03-06-2023 10:19 PM
03-07-2023 09:31 AM
@Zakiya2009 - has your plan recently renewed?
Can you try your SIM into another phone? If calls still don't work Turn off VoLTE if you have a VoLTE enabled phone. If that does not work, connect with contact customer service agent for assistance.
Perhaps you are affected by this: https://productioncommunity.publicmobile.ca/t5/Announcements/Resolved-Service-Impacts/td-p/955119
03-06-2023 10:30 PM
Yes, my plan is active and I am able to use the data and text.
03-06-2023 10:29 PM
@Zakiya2009 wrote:Both my data and text message work. On the phone call not working.
@Zakiya2009 then changing sim card won't help. You are once of those affected by the recent voice issue. Please open ticket with Pm support and they will reset your account from their end
03-06-2023 10:26 PM
03-06-2023 10:24 PM
@Zakiya2009 wrote:If I change my Sim card, do you think this will resolve my problem?
Maybe because changing sim can reset network provisioning but sims don't usually go bad. In your account, does it say your plan is active?
03-06-2023 10:24 PM
@Zakiya2009 changing sim might not help
PM has been having voice issue on the last couple days. check if text and mobile data works
I would open ticket with Pm support first and have them to further investigate before going out and buy a new sim
Please open ticket via Chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-06-2023 10:23 PM
My phone is unlocked though I used another Sim card on my phone and it works.
03-06-2023 10:22 PM
03-06-2023 10:20 PM
Nothing works? Restart your phone as that can make the phone reconnect sometimes. Check www.devicecheck.ca to see if your phone has been blocked.
03-06-2023 10:19 PM
I don’t know why my Sim card stop working and my phone number is out of service even though my plan is still on. What should I do? I hea
