05-16-2024
05:49 PM
05-16-2024
05:56 PM
computergeek541
Why is my speed so slow? I have 5g plan
I get low of 2.5 down low of .25 up
High of 70 down 2 up
05-16-2024 08:00 PM
Yes on 5g plan. Yes reset network connections, rebooted. Support ticket submitted waiting for response
05-16-2024 07:58 PM
HI @Darren8
do you have a 5G plan or 4G plan?
PM uses same Telus network, so really no reason you get a speed so much lower than when you were in Telus.
Try Reset All Networks and test again
if still slow speed, ask support agent to refresh your account.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
05-16-2024 07:53 PM
With Telus it was no comparison
05-16-2024 07:53 PM
Pixel 6. Connected to both 5g and lte
05-16-2024 07:34 PM
@Darren8 What phone do you have? Do you have it set to connect to 5G or 4G/LTE?
05-16-2024 06:03 PM - edited 05-16-2024 06:05 PM
@Darren8 - It can be caused by numerous things such as these:
It depends on location, for example, Calgary has more towers because it has many customers and needs more bandwith but when you are at... lets just say Fort McMurray, which has lots of less towers.
If you look here: https://www.ertyu.org/steven_nikkel/cancellsites.html?lat=55.153766&lng=-112.675781&zoom=5&type=Road...
And see a tower that consists of 2100mhz, 1900mhz, or 2600mhz and just those three mhz types, no other mhz it may mean that it is a limited range small cell or a picocell, with no general range.
Also check what degrees the MHZ is on your closest tower is, if it is pointed outside your direction, your phone may not receive it. If it is OMNI it is Omnidirectional band therefore you should be able to receive it 360 degrees while keeping the same band.
If it is experiencing the issue over two locations far apart from each other, please see if you had just switched to 5G plan it may take a bit for all towers to realize your change in plan speed, if it is still ongoing, please contact CS_Agent:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article! ⚠️
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
