05-01-2024 12:30 PM - edited 05-15-2024 11:29 AM
[Update as of 9:00AM ET 15/05/2024]: A solution for this issue has been successfully implemented last night. Any customer who experienced issues with their SMS service after transferring their number should now have their service fully restored.
Please note that moving forward, customers transferring their number from another provider may need to wait up to 1 hour after the transfer for SMS services to be fully initiated.
Hello Community,
We want to address a current issue some of our customers are experiencing. After porting their phone numbers to Public Mobile, a few customers have reported not receiving text messages. We are actively investigating this issue and working to resolve it as quickly as possible.
Immediate Solution:
If you've recently ported your number to us and are facing issues with receiving or sending texts, please contact a Customer Support Agent directly via our chatbot. Our agents are equipped to apply a fix that should resolve the issue promptly.
We appreciate your patience and understanding as we work through this. Rest assured, we are doing everything we can to ensure a smooth experience for everyone affected. We will keep you updated on our progress.
- The Public Mobile Team
3 weeks ago
It is the port-in issue. PM should state in the instruction to port-in a number use the previous provider sim card until the service lost before put it in the new PM sim card. I put the new sim card not long after i activate PM service, then i miss the port out message from the previous provider.... when i figure out. The port out process is expire and need to call PM during the business hour to fix the issue.
3 weeks ago
If *only* data is working, its a different issue and probably related to the number not being ported.
If its an issue like this one, incoming voice calls will work on your phone number but text messages won't.
You should use the chatbot to put in a ticket. Click the chat icon in the bottom right corner to get started on that.
3 weeks ago
I am facing this issue, my imessage and facetime is not working showing "verifying" for many days, i tried reset of network setting but no luck. please help me out.
3 weeks ago
I just hope that i will not lose my number.....
3 weeks ago
I believe it is still ongoing...... ihave the same issue. Only data works.
4 weeks ago
Yes you can get an esim abroad. As well as public does have an option of 5G, it all depends on the plan you choose.
4 weeks ago
It took 2 days for them to reply to me and it still wasnt fixed. I am not serviced by Public mobile anymore.
a month ago
same here
05-31-2024 04:17 AM
Is Public Mobile 5G? Can i get its eSIM abroad?
05-24-2024 08:15 PM
For me, I ported and started my service today (can/us 50 GB) and had many issues. I ported from speak out and speak out ported easily and quickly
Earlier today I only had data and calling (calling dropped many times) but texts didn't work. Now only texts and calling works but data doesn't work.
This is frustrating as my old sim card has been deactivated too
05-22-2024 01:59 PM
Some of my text contacts are receiving on the 'assigned' number, not the ported number. I signed up for PM back in March. The problem existed then, and I was hoping it would go away.
When I log in to PM, the 2-part authentication sends the code to my 'assigned' number, so I have to request it via email every time.
I'm also getting quite a few dropped calls, and I hope this can be resolved as well. I have requested a customer service chat, so just waiting to hear back.
05-22-2024 11:30 AM
***FIXED****
It is an issue with RCS chats. When this function is switched off everything works as normal.
05-21-2024 06:09 AM
Thank you. I am experiencing this problem currently with only some contacts . Their names have the PR box.
05-17-2024 08:10 PM
I ported today and unfortunately I am having text problems. I signed up with a new Public number and then ported over from Koodo a few days later. I can receive calls and texts from both my original public number as well as my recently ported number. Outgoing calls correctly show up as my ported number, it seems like just outgoing texts are showing up as the original public number.
Any fix other than opening a ticket? It's been 8+ hours since I ported.
05-17-2024 02:52 PM
HI @cmson
able would be able to help and resolve it quickly. You just need to check your Community inbox for their response after you submitted the ticket
05-17-2024 02:51 PM
I can receive calls fine. Just SMS is not working on iPhone. And when iMessage tries to activate it is stuck.
05-17-2024 02:49 PM
hi @cmson
but can you test if you can receive calls?
if no inbound calls as well, it is a problem with porting
but if just not receiving sms, then it might be something wrong on the account. Please submit a ticket by direct message
05-17-2024 02:43 PM
I'm facing issue with not receiving SMS after porting number today.
05-17-2024 01:21 PM
So people are still messaging that they have ported two days ago and are still unable to send or receive text messages. I thought this was fixed? Is this a new issue or is this still ongoing? How many new reports do you have ever since Wednesday? @Ck_PM
05-15-2024 06:02 PM
I hope it stays....
05-15-2024 05:45 PM
Nice to hear that you resolved it!
05-15-2024 04:51 PM
@zaptor99 wrote:Can you please improve your Eversafe so that we ALWAYS have the option to receive the verification code by email and not SMS. I know we can hit resend code and the option to use email is shown, but that's not always the case, and it only works if it was verified by SMS before.
If service is not working or we lost the phone, we need to access our account easily using email verification.
@zaptor99 , I removed my phone # from my EverSafe that way I always receive the verification code to my email.
05-15-2024 04:37 PM
05-14-2024 05:46 PM
SMS problem solved. Kudos to the agent, Razvan, for this. It involved a backend account network reset or similar. PM needs to attend to this multi client system issue to prevent bad press/postings per below and needless loss of clients.
05-14-2024 02:56 PM
Good luck to the rest of you. I have all my numbers ported off to Bell - simple and just "worked". No futzing about, no BS, no trouble.
Now - the downside, is PM will NOT refund any of my costs for the 3 failed services that I bought from them. I guess from the perspective of Telus/PM - it's a good model. They collect $ and don't deliver what is promised, the customer leaves and they don't have to refund any money. So - they get 3xMonthly cost in revenue - delivered a portion of the promissed service for 2 days, cost me a day of my life and about 12 messages to support (who really try I think?) and I get the expense of $ and time to move the services elsewhere, where it just works.
This is the WORST technology experience of my life and until/if I receive my refund - I will use any and all avenues to communicate how shady and crappy this experience has been.
Now - tip to PM - if you can't provision a line properly because of a known problem, and are relying on a consumer to log a ticket - and you are dependent on your army of support folks to fix each line one by one - you need to do a couple things differently.
Either simply - batch/auto perform the tasks, or stop taking new subscriptions until your provisioning systems work properly.
05-14-2024 02:49 PM
SMS is the key issue. I already sent a message to the support agent.
Also having problems with vmail. Calls from a cell phone (from a mobile on PM and a mobile on Koodo) don't go to vmail, but does go to vmail from a Rogers home phone. This is minor compared to SMS, but welcome all fix suggestions.
05-14-2024 02:10 PM
HI @RoroP
was it just SMS or other issue too? if SMS, please message support agent
if other issues, share and we will try to help
05-14-2024 02:08 PM
Adding on ...
My partner ported-in from Koodo - No issues (all Telus).
I ported-in from Rogers - Disaster.
Assuming there is a carrier related port-in issue, it would be good for PM to keep clients and prospective clients informed.
05-14-2024 02:00 PM
Ported-in my number yesterday. No SMS and voice operation is not fully working also. Can't login without SMS code. Can's use other services without SMS validation. Wow. Hugely disappointing!!! A critical issue with no solution for 2 weeks? Sent a private message via community for assistance. Waiting for response but not too positive on resolution based on many other replies. Common PM - 2 weeks with a critical issue and scant progress updates.
05-14-2024 01:00 PM
Already in the process of porting out to freedom. Hope PM won't exist and I hope everyone ports out
