2 weeks ago
Re public mobile…..have been using it now for a couple weeks.
So far everything seems to be working ok although it sometimes feels like it is a bit sluggish hooking up to wifis and once it does, fading in n out for a while till it becomes solidly linked. Nothing scientific though . Will this be an ongoing issue or is there something I can check into?
2 weeks ago
hi @Maryssa_2000 make sure your iOS is updated
try Reset network settings and re-join your home wifi again
and you had same issues with out devices at home?
2 weeks ago
I know this doesn’t have to do with PM, but I know I have the same issue a lot, i find turning my wifi off and on at least temporarily fixes the problem, but I’m almost wondering if it has to do with the fact that I have an older generation phone (I have an iPhone 8, and my sister had similar issues when she had an iPhone 8 aswell)
2 weeks ago
HI @Clapodie
wifi or mobile data?
if Wifi, it is a home internet problem. reboot phone and test it closer to the home router
if mobile data, try Reset All Data
2 weeks ago
@Clapodie Wifi has nothing to do with PM that your home internet provider or modem issue
