12-13-2024 12:23 PM
I just changed my subscription with public to Canada US Mexico call and data plan but when I’m not on Wifi my data does not kick back in.
12-13-2024 12:56 PM
12-13-2024 12:56 PM
Thanks the reboot worked
12-13-2024 12:51 PM
@Acura Since you're seeing AT&T but not getting data, are you on 5G, 4G/LTE or..? If on 5G try dropping the setting to 4G/LTE. Does everything else work, texts and voice calls?
12-13-2024 12:48 PM
12-13-2024 12:43 PM
In my settings it say AT&T
12-13-2024 12:42 PM
@Acura Reboot device , simply power off phone and power it back on is called rebooting the device
12-13-2024 12:40 PM
How do I do reboot
12-13-2024 12:40 PM
No confirmation to any service I’m in Mazatlan
12-13-2024 12:39 PM
@Acura What country are you in currently?
12-13-2024 12:29 PM
@Acura , are you able to confirm connection to T-Mobile, AT&T or Verizon? Also check that roaming data has been enabled.
12-13-2024 12:27 PM
How about other services? SMS/calls? Do they work?
Do you actually SEE your new plan on My Account? How much data that new plan has?
Maybe reboot will help?
12-13-2024 12:26 PM - edited 12-13-2024 12:26 PM
@Acura Reboot the phone or reset network settings see if that helps
