10-15-2024 01:10 PM
Hello , I am on a 5g plan I used to get speeds in the 100mbps now I only get between 0.49 mbps to. 1mbps I did reboot my device multiple times made sure I had the latest updates , I have not just changed plans I am on the same plan I had months ago when the speeds were fast . Not sure what to do now if anybody has suggestions it would be greatly appreciated . Thanks
10-15-2024 10:53 PM
I've been experiencing the same issues for the past few days.
10-15-2024 01:21 PM
@Seabass383 Try your phone on 4G/LTE see if it improves the speed . You can also try and rest network settings see if that helps . If still no luck confirm with support
10-15-2024 01:13 PM
It could be some issues in your area. Most likely nothing to do with your phone/sim.
You could try your sim in another phone to eliminate phone issue,
