02-03-2025
05:09 PM
02-03-2025
08:01 PM
computergeek541
Why do I have to contact public mobile to be able to use a personal hotspot on my phone, when I used an eSIM I didn’t have any problem using one and now that I have a physical SIM card it won’t let me it says contact public mobile, I always find my data is so slow compared to bell
02-03-2025 07:54 PM
@Meow I understand why OP asked, some providers block the use of hotspot, so it might not really be just device problem with other providers
02-03-2025 05:22 PM
Android or iPhone?
if you have an iPhone, APN for hotspot should be just sp.mb.com (Settings -> Cellular -> Cellular Data Network -> Personal hotspot )
02-03-2025 05:19 PM
hi @Gmefamily
you don't have to contact support for hotspot, it is never blocked
so, it is just a device setup problem. Please with reboot the phone, then Reset network settings
also, make sure you have the latest OS (or on iPhone, iOS update and Carrier Profile update
