02-03-2025 06:55 PM
02-03-2025 08:02 PM - edited 02-03-2025 08:03 PM
@Rdfoot6508 wrote:never received my PIN plus i can't log into my account
Are you are recently new Public Mobile customer? For quite some time, there is no account PIN on new Public Mobile accounts.
02-03-2025 07:32 PM
first login My Account using Incognito mode
once logged in, paste this link to the address bar
02-03-2025 07:21 PM
@Rdfoot6508 wrote:when i click on the link it says forbidden A1
Go into your browser settings and clear the cache. The restart the browser and log into your account, then click on the link again.
02-03-2025 07:12 PM
02-03-2025 07:10 PM
thanks i will try the link hope it works as i still have not been able to login to get my account #
02-03-2025 07:08 PM
@Rdfoot6508 wrote:the 4 digit PIN i will try calling the number
Hey @Rdfoot6508
CLick on this link and you can change your PIN here.
02-03-2025 07:05 PM
02-03-2025 07:02 PM - edited 02-03-2025 07:06 PM
Are you referring to the 2FA code or the PIN when you called 1-855-4PUBLIC on the status of your account?
If it is the 2FA code, just click on Resend Code or Didn’t Receive Code and have it sent by text or email.
If it is the PIN, you can reset your PIN.
