08-09-2026 11:37 AM
08-09-2026 12:36 PM
That is a function of YOUR phone nothing to do with service provider.
08-09-2026 11:46 AM
PM does not block the use of hotspot.
Are you encountering any issue?
08-09-2026 11:43 AM
The hotspot should work on PM but it is the phone setting that you need to setup.
What phone do you have?
08-09-2026 11:42 AM
@Mitch1969 wrote:Does my plan support hotspot? I can't seem to get mine to work.
Hello @Mitch1969
Yes, you can hotspot from your phone. Google on how to do it and set it up correctly. For my iPhone, it was super easy. For my Android, it was a bit different but was able to set it up.
