10-13-2024 11:17 AM
I don’t understand how an LTE plan can possibly be this brutal, other than public throttling data and thinking customers won’t notice? No, I’m not out of data…I’ve used 3/50 GB for the month. Yes, I’ve reset my networking settings, restarted the phone, etc. I’ve tried in different spots in my city with the same result. I can’t even watch a live TikTok without buffering.
Funny thing is the speed test starts in the 100mbps range, then gradually drops to under 10mbps leading me to believe public throttles and thinks people won’t notice. What a load of B.S.
fix this or I’m gone!
10-16-2024 12:21 AM
the $39 plan
80G
10-16-2024 12:19 AM
I have the 5g
10-15-2024 10:42 PM
@Brandimatt wrote:What is a good speed anyway? I'm at 47
This depends on which plan you're on. The speed that you're used to also determine what would be consdiered good for any specific person. I know that's not really the type of answer you're looking for, but a good speed is whatever any particular user is happy with. Network conditions are also a factor and the speeds advertised by Public Mobile are only maximum speeds.
10-15-2024 10:28 PM
10-13-2024 03:06 PM
hi @bonezz82 I don't think they throttle video, just the overall data is slow today in some area
10-13-2024 03:00 PM
Why do they throttle video? What a ridiculous company… glad I get my chatr sim tomorrow.
10-13-2024 02:42 PM
Video is throttled. Try using a VPN and see if that helps streaming playback. The speed test does seem low.
10-13-2024 02:14 PM
I did open a ticket, but I feel like PM service has been oversold in my area and doubt CS will do anything. Throttling seems to be common with PM also…
10-13-2024 02:12 PM
To me it seems more like the company is throttling. Probably reserved for Telus customers who pay double.
10-13-2024 01:57 PM
hi @bonezz82 do you have a 5G phone?even you have a 4G plan, you can access 5G network, check if it works better
10-13-2024 01:52 PM
Wifi was turned off, otherwise I get 500+ mbps
10-13-2024 01:51 PM
No, Kitchener Ontario
10-13-2024 01:44 PM
@Wayworn wrote:Why is there even a 3G option ? I don't think 3G plans are still available.
I still have a 3g plan ($15)...2.8 download and 2.9 up.
10-13-2024 12:17 PM - edited 10-14-2024 10:24 AM
Slow data reception/speed is not unique to PM. I thought a 5G plan would improve speed but -- in my case anyway --- it has not. Even at 5G sometimes my phone just spins and spins trying to load the page. Maybe our over population with cell phones is at times overloading the system. —-
10-13-2024 11:27 AM
Hey bonezz82,
Man, I feel your pain—I've been there too with the slow data, and it's super frustrating. Especially when you're nowhere near hitting your data limit. From what you're describing, it almost does sound like some sort of throttling, but they usually only do that after you've hit your data cap, so this is weird.
One thing that sometimes helps me is toggling between LTE and 3G for a bit, even though it's a slower network, just to see if it temporarily fixes the speed. I know you've tried different spots, but sometimes network congestion can be wild at random times of the day.
If that doesn't work, I’d recommend reaching out to Public Mobile support through their ticket system. It sucks that we can't just call someone directly, but they’ve helped me out in the past when I had a similar issue.
Hope they fix it soon, man. If not, I totally get why you’d want to switch.
Good luck!
10-13-2024 11:25 AM
hi @bonezz82 are you in Vancouver area? there has been problem with LTE and 5G in Vancouver area for last 2 days
10-13-2024 11:20 AM
@bonezz82 yes many have same complaint also note it’s up to 100mbs on 4G plan dosent mean you will always get 100mbs but 12.6mbs is to slow .
also when you do the speed test you should have wifi turned off to test
10-13-2024 11:19 AM - edited 10-13-2024 11:22 AM
@bonezz82 wrote:I don’t understand how an LTE plan can possibly be this brutal, other than public throttling data and thinking customers won’t notice? No, I’m not out of data…I’ve used 3/50 GB for the month. Yes, I’ve reset my networking settings, restarted the phone, etc. I’ve tried in different spots in my city with the same result. I can’t even watch a live TikTok without buffering.
Hello @bonezz82
First, you need to realize we are all customers like you here on this forum. Public Mobile does not monitor these boards. For that reason, you need to create a ticket to get help. Here's how.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
EDIT: I just did a speedtest in my area (Winnipeg) and got 107 down and 9.5 up. And I'm on 4G.
