07-15-2024
09:21 AM
07-15-2024
02:34 PM
computergeek541
I have gotten rid of my la dline ,but my wife needs a phone,should I activate a new line in my name,or let her do it and I get referral bonus or do I get the bonus as a second line?
07-15-2024 12:05 PM
Thank you!
07-15-2024 10:17 AM
07-15-2024 10:01 AM
@slusagm wrote:actually alias is troublesome. while gmails allows +, Eversafe has trouble with gmail alias with +, there is problem with 2FA sent to email for those with +
Thanks for the headzup. I musta got lucky then. I manage an acct for a relative and use gmail alias without problem....so far !
07-15-2024 09:54 AM
07-15-2024 09:50 AM
you'll need a unique email address to activate a new acct for wife. Gmail does support alias if you use gmail. (ie: DDD@gmail and DDD+1@gmail)
07-15-2024 09:26 AM
you cannot use your email to set a 2nd line. So, ask your wife to use your referral code, setup her line , she will get $10 one time and you get 1 point every cycle
07-15-2024 09:25 AM
07-15-2024 09:24 AM
The second line needs its own separate email address login and account. It does not matter whether it is under your name or your wife's.
When your wife signs up, make sure that she uses your referral code when activating her account. The new account will get $10 in available funds within 72 hours, while the referer will get 1 friend points/month as long as new account remains with Public mobile.
