Sim card not working in new flip phone
Thporter
I am having trouble with my LG smartphone and I purchased a new flip phone from Wal-Mart online and the sim card doesn't work in it. Any ideas what the problem would be?
10 REPLIES 10
Thporter
It's a strange name it's MAFAM model F899
@Thporter  what exact model is the new flip phone?
Thporter
Yes I ordered on Walmart.ca and I tracked my phone and it had to go through customs.
Thporter
Went there but didn't work I'll try it again later. And the card works cause my LG smartphone is still working just got screen messed up also got the loan of another flip phone and it works in there.
Thporter
Uts a strange name to its mafam brand.
Chalupa_Batman
Walmart tends to purchase American phones because they are cheaper and sell for profit up in Canada. Also, if it was one of those Marketplace purchase, very good chance it's an American phone.  You want to purchase a phone here in Canada. If you have a Costco membership or know someone who does, this will work good and it's reasonably affordable.
https://www.costco.ca/motorola-g-play-32-gb-unlocked-smartphone-2023%2c-navy-blue.product.4000113022...
Or you can check Kijiji and hope for the best.
Dunkman
@Thporter
What model Flip phone?  Should work with Public mobile but there might be issues with compatibility.
@Thporter check if the new phone is blacklisted
https://www.devicecheck.ca/check-status-device-canada/
and test your PM sim in another phone as well
Thporter
Yes I have.
@Thporter @Have you tried rebooting the phone
