11-22-2024 09:16 PM
I signed up for the service about 5 hours ago and transfered my number from Videotron. I still have no data and cannot call or text. However, I can receive calls. Anybody else have this issue?
11-23-2024 10:19 PM
This did it thank you!
11-22-2024 09:47 PM
hi @kacheson what model of phone?
check your sim manager to confirm if it is enabled, set as Primary and Turn on this line is enabled
make sure old carrier sim card is removed (or if that is also eSIM, disable it)
11-22-2024 09:44 PM
I am using eSim
11-22-2024 09:44 PM
strangly enough I cannot access my apn settings (I could with my previous provider). so something is amiss.
11-22-2024 09:30 PM
hi @kacheson
what phone do you have? maybe you can put the PM sim in another phone to test
11-22-2024 09:28 PM
@kacheson , the fact that you can receive calls means the phone is able to make a network connection. If you are having data issues, please confirm that the APN settings are correct and that mobile data is enabled and data limits have not been set and triggered.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
As for not being able to call out or text, that could be an account set up issue that support will need to investigate for you. Hopefully you get a response within the hour as support hours end at 10pm eastern time.
11-22-2024 09:25 PM
Thanks for your help!
11-22-2024 09:23 PM
@kacheson They usually reply 2-4 hours sometimes longer , I think they are overwhelmed right now with Black Friday sales unfortunately. Just keep an eye on your community inbox for their reply and they will get back to you
11-22-2024 09:20 PM
Hi there, yes I've tried rebooting the phone and reset the network settings twice. Still no luck. I've put in a ticket with support. Does it usually take this long for them to reply to tickets? It's been 2 hours since I've submitted.
11-22-2024 09:18 PM
@kacheson Have you tried rebooting the phone or reset network settings yet? Try that and see if it helps . Is still no luck ask support to refresh your account
