Question
LayLiu
"Why is it that other Public Mobile users can choose a Black Friday deal that offers a $29 per month 5G plan with 10GB of data in the US, Canada, and Mexico, but I don't see this option available to me?"
9 REPLIES 9
funpig1
@LayLiu  The $29 plan would not be available to you if your current plan is more than $29. What are you paying now?
I'm currently on the $23 plan and the $29 plan is available for me.
As a general observation, PM will not offer you a plan which is cheaper than the one that you already have. Sometimes, there are exceptions to this general rule but it is rare.
The $29 plan is very attractive to me, but I have resisted changing. Do I want to pay an extra $6 per month or $72 per year going forward with very little realistic chance of downgrading to a cheaper plan in the future? I rarely use more than one or two GB per month.  I have not been to Mexico since 2007.  I make the odd trip to Hawaii every year but a travel e-sim would be very cheap. Maybe I will switch plans if I retire and buy a used motorhome to travel all over North America. Until then, I would rather save the money.
LayLiu
I found the reason; it turns out that the plan is designed for new users.
LayLiu
Indeed, I didn't notice it at the time. Thank you for your reply.
LayLiu
ok,I'll try it.😘
LayLiu
Well, thank you very much for your reply~
slusagm
not everyone sees same plan selection now. So, what plan amount you have? you see the $35 Can/US/Mex plan?  if you see it, maybe you can change to that?
or you see any plans below the $30 at all?  if you see any, you can try to trick to change to one of those below $30 plan and the $29 Can/US/Mex plan might show up after
Sylvestor
Does what you are looking at say for new subscriptions only?
hi @LayLiu that Lam you are having now
PM is using a targeted marketing now and different customers will see different set of plans available to them
you can try to ask support agent and see if they can help to change the $29 can-us-mex for you
Phil_Adelphus
@LayLiu  Typically most people are only seeing plans that are more expensive than the one they currently have, or is a targeted special offer.  Another reason is when a plan is for new activations only.  So basically if you log in to your account and select change subscription, what is on offer there is what you can choose from.
