Show my phone number
Eldon111
How to set my phone so it shows the phone number when I dial it out to another person
@softech wrote:
Alternatively, you can enable caller id by dialing #31#.
#31# blocks the outgoing call display for that individual phone call.
@Eldon111
PM has caller id enabled and you usually do not have to do anything
But you can confirm your caller id setting on the device by going to your phone's Settings, find the Phone or Call Settings option, and then navigate to Caller ID to select "Show my number" or "Show number".
hairbag1
@Eldon111
you can't. That other person must have you in the contacts list to see your name...otherwise just your number will show when you call someone. There could be a setting in their cell if it's just one person who can't see your number.
