10-20-2022 07:12 PM
Currently I have a loyalty bonus that saves me $5 per month, so is it wise to switch to the new Public Points program? thanks
Rewards
10-23-2022 06:29 PM
Ok thanks a lot haha I think I will leave it as is.
10-20-2022 11:22 PM
It depends if you want your credits to your bill every month or wait and save up 15 points and redeem for a $15 credit.
Not really worth go to the new Points system.
10-20-2022 08:06 PM
Friends don't let friends opt for Points !!
Don't do it. 😥
10-20-2022 07:29 PM
Hi @publicuser123 I had the same exact question as you about a month ago and all the advice I got was don't switch keep the all points program the only disadvantages is that you can only get up to five dollars loyalty two dollars auto pay the max you can get off is seven dollars per month plus any community dollars here.
If you do choose to switch you will lose your two dollars auto pay and possibly maximum five dollars loyalty and there's no way to get back if you do change the advice I was given stay with your current rewards program you do not have to switch
10-20-2022 07:22 PM - edited 02-17-2023 08:37 AM
Hi @publicuser123 the Community disagree a lot.. But one thing we all agree: DO NOT switch to Public Points!!!
You have $5 per cycle discount, $60 a year. New Public Points only give you 10 Points ($10 value) for Anniversary ...
10-20-2022 07:19 PM
@publicuser123 No, don't!
10-20-2022 07:16 PM
@publicuser123 Hi absolutely no you will lose way more then you will gain and there is no going back
