03-15-2025
05:13 PM
03-15-2025
05:16 PM
computergeek541
03-15-2025 05:18 PM
As a customer, you can't. You would have to contact an agent here.
03-15-2025 05:15 PM
hi @KathyE support agent can reverve or or change back to the correct one
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
