12-31-2021 03:51 PM - edited 01-04-2022 04:43 AM
Hello I am a new public mobile customer as of a couple weeks ago. My question is why do my incoming calls immediately get sent to my voicemail? I can receive calls just fine. I have visited a cellular retail store and covered all basic reset options. Device reset/network reset etc. looking for assistance.
thank you,
Kevin Keeping
01-01-2022 12:11 AM
@Kevkeeping wrote:Hello I am a new public mobile customer as of a couple weeks ago. My question is why do my incoming calls immediately get sent to my voicemail? I can receive calls just fine. I have visited a cellular retail store and covered all basic reset options. Device reset/network reset etc. looking for assistance.
thank you,
Kevin Keeping
@Kevkeeping - have you checked your device's settings to ensure:
1 - DND (Do not disturb) has not been accidentally enabled, OR
2 - is your calls set to receive from contacts only listed in your phone?
Depending on the model of your phone, open your device's Settings app.
Tap Sound, then Do Not Disturb preferences, then Priority only allows.
Set Calls to From contacts only and adjust any other preferences for this mode to your liking.
12-31-2021 08:06 PM
Does your phone show Public as the carrier?
If it does, try rebooting your phone by powering off the phone then wait a few minutes then powering on the phone.
12-31-2021 04:10 PM
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
12-31-2021 04:00 PM
Hi @Kevkeeping are the incoming calls go to your PM voicemail? Just want to confirm it wasn't a porting issue and your incoming calls still going to voicemail with your old carrier
did you try to change your network setting to 3G Only and see if it helps?
What kind of phone do you have?
12-31-2021 03:58 PM
Are calls going to your pm voicemail? Or did you port in your number and not reply YES to the PAT (porting authorization text) within 90 minutes of receiving it? Check and see if your old providers account is still active if this is the case.
Otherwise it could be an issue with your phone switching from the 4G LTE network to the 3G network that pm uses for voice calls. Switching to the 3G only could resolve the issue.
12-31-2021 03:54 PM - edited 12-31-2021 03:55 PM
thank you,
Kevin Keeping
When you activated, did you reply YES to the port authorization request?
You might try these options otherwise:
