12-25-2024 11:33 AM
I am going to be in Mexico for 6 weeks
If I change my subscription to include Mexico does this mean it covers my calls within Mexico, or does it only cover calls from Canada to Mexico?
12-25-2024 11:53 AM
you'll be able to use your cell in Mx, just as you would at home...you'll be able to call most any Mx, Cdn or US number while in MX. You can use your data freely as well as text to any north American number. Make sure to enable Roaming Data in settings. Also, be aware that when you get home...you likely won't be able to downgrade plans as once you have a higher value plan, you won't see any available plans in your account that are much cheaper than the one you have when you get home.
12-25-2024 11:43 AM
yes, you can use data, call and text like you are in Canada
and you can call locally and US and Canada while you are in Mexico
