10-01-2021 12:37 PM - edited 01-06-2022 03:28 AM
I have unlimited canada wide talk, but when trying to make a call it states I have used up all my self serve minutes?
10-01-2021 08:31 PM
@Hillierbrent wrote:I have unlimited canada wide talk, but when trying to make a call it states I have used up all my self serve minutes?
Happened to me earlier this year. Hasn't happened for months now.
I think it had something to do with Provincial ONLY plans PM started to institute, but that reversed. -YEAH!
I rebooted and/or toggled into airplane mode, then was able to make calls without that message.
Hopefully, you won't be getting these message too much longer.
10-01-2021 03:23 PM
@Hillierbrent Does the call connect if you ignore the message?
10-01-2021 03:07 PM
Usually rebooting your phone helps when lost connection to cell tower(s).
Know from personal experience...
10-01-2021 01:37 PM - edited 10-01-2021 01:37 PM
Power off your phone for 10 minutes. When you power it back up again call your most frequently called number manually dialing the digits including the (1). If it continues to give you this message for more than an hour then contact customer support to resolve it.
10-01-2021 12:47 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
*To get the obvious out of the way...you used ( +1 or 1 ) in front of the any area code,
for Example long distance, Add (+1 or 1 ) in front of the any area code,
1416xxxxxxx,
or
+1416xxxxxxx,
both is will going through your call...
Good luck and enjoy the service
10-01-2021 12:42 PM
Log into self service and tell us what plan you are on. Try putting a 1 in front of the number.
10-01-2021 12:42 PM - edited 10-01-2021 12:42 PM
@Hillierbrent Try to put a 1 in front of the 10 digits number you are calling, like 16041234567
