01-07-2022 12:30 PM
Is there a way to search, find and see all (or at least some - recent) posts by particular client?
Before you could designate somebody as a 'Friend' and then clicking on a 'Friend' showed a list of all his/her messages.
01-07-2022 01:28 PM
I am hoping they still add tags back to the get help section like in the other sections so if its a post you want to refer to again you can tag it. If you can remember a portion of the thread title then searching and just tapping "go" will give you pages of posts with that topic that you can skim thru or filter by date etc...but most times the profile posts will do it. They only go back 2000 posts in the profile so how far you can go back can be limiting for someone like me or can contain the entire posting history of a member.
01-07-2022 01:18 PM
Lol...you can't you just have to choose the best answer that serves your needs..... @Anonymous owes me a couple of half-sies so the next bottle is on him! 🍾
01-07-2022 01:14 PM
Even though it appeared that the ignore option did not work.....I do miss the friend option. But I think I know why it was removed.
This is new format seems to lessen activity in postings in general. Too bad they could not disallow pasting of responses as quite awhile back they took away macros that was a similar way to post the same answers from a stored library.
01-07-2022 12:59 PM
You nailed it @darlicious .
How can I accept two solutions as @0PX9O4 was correct too (but I wanted even more)?
01-07-2022 12:51 PM - edited 01-07-2022 12:52 PM
Put the username in the search bar and search. Then choose users. Then click on or tap the little replies icon by their info on the right.
01-07-2022 12:43 PM - edited 01-07-2022 12:43 PM
@Meow wrote:OK. Just a partial solution. This works very well if you are clicking on user's name.
What if you have to Find at least one post by that user?
There's no easy way to search only through the posts from one particular user. The best way to do this would be use the advanced search option and use the plus sign and then the username. So if I wanted to find posts by @Meow that mention search, I could search for "search +meow" without the double quotes.
Try it out and let us know what you think.
01-07-2022 12:40 PM
01-07-2022 12:36 PM
WOW! You might be very right! Let me try it a little bit and I will be back to Accept your solution!
Thank you!!!
01-07-2022 12:32 PM
For instance @Meow , here's the posts you've made in the past: https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/182855
01-07-2022 12:31 PM
Can you not click on their name and see their profile?
