Cellular data question
NadiaHryniw
"Cellular Data" Will Be Used for Calls & Messages
Until you update the contacts that were using your previous cellular plan, "Cellular Data" will be used for all calls and messages.
I tried so many times, but wasn’t able to do that, please help, thank
DDM69
Is this an error message you are receiving?  Can you post a screenshot?
HI @NadiaHryniw
are you talking about VoLTE?
or you have problem with voice in Canada or US? give us more information
@NadiaHryniw  Cell data shouldn’t be used for calls just data and text when using MMS or iMessage it’s needed
