a month ago - last edited a month ago
I suggest everybody check to see what black Friday deals are available.
My family checked and there are some deals available.
For me, I switched to a same priced $23 4G 6GB plan and received 100 minutes of international calling.
My wife switched from her $29 plan to the same plan for $25 and is saving $4 per month.
My son is considering switching from his existing $34 plan to a newly available $30 plan to save the $4. He would downgrade from 5G to 4G and he would downgrade from 50 GB to 20 GB. He never comes close to using up his data. He would still get Canada and US calling. With the new plan, he would also receive 250 minutes of international calling.
a month ago
Plans including Mexico are now available with p.m.!
a month ago
@funpig1 ,
That's good to know. Thank you. I never had the app. Never used the app. I never intended to. Maybe you got me curious, LO.L we'll see.
a month ago
hi @funpig1 I think is just a browser cache problem
try login My Account using Incognito/private/secret mode on your browser and check ahain
a month ago
I can also confirm this, a while back i received an offer on the mobile app that i accepted. I couldnt see/accept this on the website, i had to use the app and schedule the change there. It was no issue to me, but i wouldnt have even noticed if i didnt check the app. So it does help to check both places if you are shopping around/looking for a deal.
a month ago
The available subscription plans on the PM app and the available subscription plans on the website using my PC browser have differences.
For example, my phone app offers a $23 plan with 100 international minutes. On the computer, offers the $23 plan without the 100 international minutes, but gives you the option to sign up for a 90 day plan.
People will probably see different offers depending on their existing plans. Good luck.
If you decide to change, I suggest that you take a screen shot of the terms of your new subscription.
Currently, I set to change on renewal. However when I view the "upcoming subscription", the terms are exactly the same as my original plan (i.e. no mention of 100 international minutes). My plan is scheduled to renew on Nov 22, so I will know soon.
Also, when I checked the PM account on my PC, the terms of the promotional $23 are different. On the PC, it offers the option to select a 90 day plan (not available on the mobile PM app). Presumably, you get the 18GB over the 90 days. However, there is no reduction in price.
a month ago
@slusagm wrote:thanks. I just checked, and they took away all the 90 days optoin.
What's available in your account doesn't necessarily mean that another account will have the same plan options.
a month ago
a month ago
hi @MaraWaters
no worries, you won't lose any of the friend referrals or any add-on on your account. Just the plan will be changed and nothing else
a month ago
Do you know if switching to the $25 10GB plan, would I lose refer-a-friend promos that I currently have on my subscription?
a month ago
thanks @funpig1
Yes, I think the $25 10GB is a new plan
