Samsung S7 status bar showing provider?
11-10-2021 05:45 PM - edited 01-04-2022 05:11 AM
Is there a way for provider's name (PM) to be shown on Status Bar on Samsung S7?
It will be helpful to quickly know when phone is connected to network having PM name there and not looking for tiny signal symbol.
Phones
11-11-2021 06:15 PM
Oh, thanks @softech, I did not know that because I don't use QuickStar personally.
The dev team is kinda slow with updates and fixes imo, but they're a part of Samsung so I'm sure this bug will get sorted out...eventually...lol
11-11-2021 05:47 PM
@fujiyama I don't think QuickStar has the option.
I have actually been using it.
it has Homescreen: Show network information on the idle
Lockscreen : Show Network information on the keyguard
I turned on both, the Lockscreen did show the Network name but not the Homescreen.. at least not on the status bar on top
I think the first option ( Homescreen: Show network information on the idle) supposed to work , but I see people on the Samsung Community complaining that option did nothing .. so, it might be a bug
11-11-2021 05:33 PM
11-11-2021 01:07 PM
My Moto E4 shows provider's name in status bar. It looks like it depends on a phone's brand.
11-11-2021 12:37 PM - edited 11-11-2021 12:38 PM
@Anonymous wrote:My Samsung A31 running A11 shows the carrier when I pull down from the top for those quick buttons. It's (they're) at the bottom. I don't have a SIM in my S7 at the moment.
Yes I now, when I pull down from the top, Public Mobile appears on the bottom. Not that handy but at least something. I thought there is some kind of secret setting in developer's mode or regular settings.
But thanks everybody for comments and suggestions. At least I am not alone in missing some handy features.
11-10-2021 08:38 PM - edited 11-10-2021 08:40 PM
@softech wrote:@dabr . but i guess there is one thing in common. .Samsung does not like to have the carrier brands on the status bar for any of its models 🙂
@softech Perhaps not on the status bar but I know I've seen the name on the lockscreen on another Samsung model though, just the S7 doesn't show it anywhere.
11-10-2021 08:35 PM
11-10-2021 08:32 PM
11-10-2021 07:57 PM
It really depends on the model, Both S21 and Note 9 doesn't have that with the pull down. But it does show on the lock screen
11-10-2021 07:53 PM
11-10-2021 07:43 PM
@Meow I think the carrier name not being shown in the status bar generally applies to most modern Android phones. Though, you can download a 3rd party launcher that has the ability to show the carrier name. I remember some old Androids locked to carriers like the Moto G 1st gen. (Launched in 2013) may have shown the carrier name.
11-10-2021 06:29 PM - edited 11-10-2021 06:32 PM
@Meow you know what.. it might be something that Samsung purposed hide from the status bar. I just checked 3 Samsung phones and they don't have that on the status bar.
However, it is on the lock screen. not sure if this is good for your purpose
11-10-2021 06:04 PM
@softech wrote:is this an S7 issue? seems like it is common. I see people asking it, too
this page suggest to use an app for showing the network :
Thank you @softech for suggestion but I am sure I saw provider's name on top bar before (maybe not on my phone??) without 3rd party apps.
Let me do some more digging to confirm that. Thanks anyway!
11-10-2021 05:55 PM
@Meow wrote:Is there a way for provider's name (PM) to be shown on Status Bar on Samsung S7?
Not sure if this helps...let us know.....
Go to Settings > Mobile Networks.
Tap on Network Mode.Select the second WCDMA/GSM (auto connect) option.
Then select Network operators and tap Search networks.
Once the search is complete, select your Carrier. Test your device.
11-10-2021 05:53 PM
