Samsung Galaxy XCover 4
cwoykin
I know it’s not listed but wondering if anyone is using the Samsung XCover 4 with Public Mobile?
@popping I knew, of course, what you meant. That is not the only site that thinks PM operates 2G. No doubt they believe Bell does too. Robot LOL
popping
@Luddite wrote:
@popping That site seems a little wonky given that it shows compatibility with 2G, a network PM does not have.
Agree. The 2G(GSM) is wrong. Some how that site thinks that PM support GSM on all phone specs which I searched before.  My recommendation was based on 3G and LTE specs.
The 3G and LTE specs are correct according to Samsung Canada specs.
https://www.samsung.com/ca/smartphones/galaxy-xcover4-g390/
  • 3G UMTSB1(2100), B2(1900), B4(AWS), B5(850)
  • 4G FDD LTEB1(2100), B2(1900), B3(1800), B4(AWS), B5(850), B7(2600), B12(700), B13(700), B17(700), B20(800), B29(700), B66(AWS-3)
geopublic
@cwoykin  It will work. That phone supports the following bands:
3G4G
850(B5) / 900(B8) / 1900(B2) / 2100(B1)
LTE 800(B20) / 850(B5) / 900(B8) / 1800(B3) / 2100(B1) / 2600(B7) | TDD 2300(B40) / 2600(B38)
popping
Check the model number of your Samsung XCover 4.
If you have the SM-G390W or SM-G390F, it will work with PM according to the following check
https://www.frequencycheck.com/carrier-compatibility/Lzarn/public-mobile-canada/devices?utf8=✓&q%5Bf...
