08-18-2019 02:45 PM - edited 01-05-2022 06:28 AM
not sure where to go as this is the first time i have had an issue however my plan isn't up till the 27th of August and i have not had phone nor text in two days. At first i thougth it was an issue with the network now i am not sure.
Can anyone help with this issue or send me in the right direction.
Located in Nova Scotia
08-18-2019 03:08 PM
@Fee8002 wrote:I am currently on the $25 a month unlimited talk and text plan
Somewhat unrelated to your (now solved- yeah!) problem.... And none of my business... But:
Assuming that you are on the province wide talk / international text plan. Have you considered upgrading to the "new $25 plan"? It would give you Canada wide talk, international text plus 1GB of data (if you are on auto pay) for the same price.
In your self serve go to plan change, select the ready made $25 plan and make sure to click on "change at next renewal".
08-18-2019 02:55 PM
ok I feel like a moron.... we will blame that on mommy brain. Phone is working now after restart.
Thank you for the simple fix.
08-18-2019 02:54 PM
@Fee8002 check in your self serve or dial *611 to see if account is active
08-18-2019 02:50 PM
i have been using the phone and the plan for almost a year with no issues until the last 2 days...
08-18-2019 02:49 PM
08-18-2019 02:49 PM
@Fee8002 you should start by restarting your phone. Then check your self serve account to see if the plan is active still. I'm in nova Scotia and I Havnt had any problems with the network!
08-18-2019 02:49 PM - edited 08-18-2019 02:49 PM
@Fee8002 wrote:not sure where to go as this is the first time i have had an issue however my plan isn't up till the 27th of August and i have not had phone nor text in two days. At first i thougth it was an issue with the network now i am not sure.
Did you buy the phone used? Check the blacklist in case it was marked as stolen after the fact.
Is it an iphone 6? Apparently they have issues with the antenna.
What plan are you on? Maybe you've used all the minutes in the $10 or $15 plan and/or maybe you've used all the texts in the $10 plan.
08-18-2019 02:47 PM
@Fee8002 hi what plan are you on?
