02-26-2022 09:10 AM
Hi there, i left Canada almost 1 month already, i wanna stop my plan but keep my number.
But i dont know how to process it.
Can you give me a hand for this case?
Thank you so much and have a good weekend.
02-26-2022 02:52 PM
I do not recommend removing your payment card details in case you have trouble adding them again when it comes the time to pay and reactivate to avoid losing your account/phone number. Assuming you are on the old rewards program that is much better than the new points program porting out to a voip would mean you would lose this benefit as well as any grandfathered plan you may be on or any promotions you may have. My preference is to use lost/stolen to suspend your service. Here are your options....
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels and Stay--Safe!
02-26-2022 12:28 PM - edited 02-26-2022 12:30 PM
How long will you be away from Canada? If it is less than 90 days, just remove AutoPay and CC information.
If you can’t make it back after 90 days, your number will be lost and account closed unless you switch to a $15 plan so you can retain everything.
02-26-2022 09:56 AM
- Downgrade plan to $15
- Remove autopay
- Remove credit card info (just in case)
On next renewal your account will be suspended due to no pay. You will have 90 days to reactivate plan. Log in around 88th day, add funds to account or manually pay for the next month and you will be good for another 90 days of no service BUT will keep your number and account.
02-26-2022 09:51 AM
Hi @Spudster the suspend for 90 days trick is good but troublesome for people as you MUST reactivated within 90 days. Again, around 85th days is the best as it gives you time if you have trouble with payment
How long you will leave Canada for? If you are going to leave for over a year, you might think to port out to a VoIP provider to park the number for free (or a one time small fee). However, since you left Canada already, depends if your PM SIM is now in Canada and if some friends can help you with the porting. But with this solution , you save more $ and save the trouble about reactivating every 90 days
02-26-2022 09:19 AM
Thank youuuuuu
02-26-2022 09:19 AM
Thank youuuu
02-26-2022 09:15 AM
Login to your self serve and use lost/stolen phone link to suspend the account.
when was your last renewal?
Make sure you come back to reactivate after 85 days or so cos after 90 days your number is cancelled and account closed.
Remove your autopay if you want to make sure that you are taken off the list.
02-26-2022 09:14 AM - edited 02-26-2022 11:06 AM
Simple @ellery
Let the plan expire, after it suspends, you'll have 90 days before it becomes permanently deactivated. If you're gone LONGER than that from the date it is suspended (login to self-serve to see), you need to reactivate on the cheapest plan $15 to prevent it from being lost.
Once you're back, simply process a payment to get it going again, and you'll retain the same number.
[EDIT: Yes, as @hTideGnow mentioned, if you're going to be gone for maybe a year, might be wise to consider switching# to a VoIP provider, however with my above recommendation, you'll end up paying just $15 for up to 210 days and keep your number. (90 days current suspend period + $15 30-day renewal + 90 days next suspend period) . Again, key is to login to self-serve to see what's remaining in the suspend period and not let it go beyond the 90 days. ]
