SOS Only
10-07-2023 08:08 PM
05-21-2024 09:10 PM
Thanks for the help today. I spoke with a CS Agent and had the issue sorted.
In case others run into SOS error in the future, the solution was to replace the SIM card with a new public mobile one. My last SIM from public mobile was nearly 8 years old and I guess they just die after extended periods of time. Hope that helps others
05-21-2024 12:51 PM
@Tea_Lively Have you checked the outages map?
https://www.telus.com/en/outages
If you end up needing customer service and the chatbot isn't helping then you can private message customer support directly using this link
05-21-2024 12:49 PM
HI @Tea_Lively
try to pull the physical sim and put it back
or try it on another phone
and last, did you check your My Account? is it showing your account is active?
05-21-2024 12:46 PM
Hello,
Not a new activation. Have been with public mobile for a few years now. Today my iPhone 15 only shows SOS and I cannot connect to 5G or any other service. I have no service for calls or texts. Can only get iMessage on wifi. Just shows SOS.
I tried to create a ticket but got a 404 error. Now going around in circles with AI chat bot and getting no where.
I’ve tried many restarts, removing and reinserted SIM card, going into Network Settings and removing Automatic. All without success. I’ve also confirmed my account is active and payments are up to date.
Under iPhone settings > About > physical SIM > Network - it shows not available. But under carrier it shows Public Mobile
Please help!
05-21-2024 11:56 AM
HI @Tea_Lively
new activation? if it is , then the sim was not properly setup. Support agent can help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
05-21-2024 11:52 AM
I’m in the same boat as original poster, but this hasn’t sorted the issue. Still shows as SOS. Any other suggestions to fix?
10-08-2023 10:02 AM
@RThomas "I was able to confirm that the SIM card works in another iPhone." Can you try another working sim card in your phone? If your sim works in another phone then it could be your phone that has a problem. If another working sim also has a problem with your phone then that could confirm it.
10-08-2023 04:28 AM - edited 10-08-2023 04:29 AM
Your iPhone is not reading the SIM.
A friend installed his SIM backward and had the same issue. His sight is not a good as he is approaching 70. Good thing he didn’t damage the SIM tray but did damage one corner of the SIM.
Make sure the 45° notch lines up with the notch on the SIM tray and reboot your phone by powering off then back on.
10-07-2023 09:18 PM
@RThomas wrote:@CS_Agentin our Community
Hello. I’m seeing SOS Only on my iPhone. I’ve tried removing and reinserted SIM card, resting Network Settinngs and restarting iPhone without success.
I’ve also confirmed our account is active and payments are op to date.
Can you please help
@RThomas , since your SIM Card works in another iPhone please check to see if your iPhone has a carrier settings update (Mine updated to 55.0)
If you haven’t yet update your iPhone to the latest iOS 17.0.3
I can’t think of anything else sorry 😔
10-07-2023 09:17 PM
Having the same issue. Phone has worked for months with public mobile, randomly went into SOS and can't get it out.
10-07-2023 08:58 PM - edited 10-07-2023 09:03 PM
Android phones have unwanted junk installed on them, too. If you happen to get a model and version that decides you aren't going to turn off features like SOS, Find My Device, or Amber Alerts then so be it, they will run (and they will consume your data) and you have no say in the matter.
But Android device owners with internet access (almost) always have the option to root or superuser. Bypass all the limited user privileges installed by some managerial at the phone factory. If you don't want SOS (or whatever) on your rooted device then you can disable or uninstall it like any other unrestricted app.
Alas, iOS devices don't really offer any options for rooting. They've designed a system where the evil, sinister, subversive, taboo practice of "jailbreaking" them basically lobotomizes half the features which make them useful and appealing. iOS devices are fantastic and innovative in many ways ... but the UI-locks and privilege-locks and account-locks are the deal breaker for me (and for many others).
10-07-2023 08:50 PM
Hi @RThomas
Go into the settings, then to Cellular, then to Network Selection and remove automatic. Then pick Public Mobile and reboot. Let us know if that works.
10-07-2023 08:40 PM
This is not a new phone, it has been used for quite some time with Public Mobile.
10-07-2023 08:13 PM
@RThomas is this a new iPhone you just got? for peace of mind, check if the phone is clean
10-07-2023 08:10 PM
hi @RThomas is this a new phone or it works before?
you have another phone to test the sim card?
