07-31-2025 08:45 PM
My plan renewed on the 29th and since then the data stopped working. Calls and texts still work, but no mobile data and the usage on the app is not loading.
the only difference between last month is that I changed the payment method, but even then it is definitely paid and renewed correctly.
tried restarting the phone but no luck!
08-03-2025 10:02 AM
Thank you for your reply.
I did as you said and got a ticket in, and chatted with someone but still they couldn’t help fix it and the data is still not working!
any help would be appreciated, thanks 🙏
07-31-2025 08:54 PM
@Hanansam6 wrote:My plan renewed on the 29th and since then the data stopped working. Calls and texts still work, but no mobile data and the usage on the app is not loading.
You can try going into the network settings and reset them. If not, you can reach out to a CS Agent to reset your network on their end.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
