How can I talk to a person.
Shane87
The chat bot is continously going in a circle because it can't help. I paid my fee 2 weeks ago and my account has be disconnected.  I've been trying to seek help for 2 days and I'm just getting the run around
hi @Shane87
could be a phone problem or location .  Try Reset network settings
try your sim in another phone
also, try in different area
Shane87
I am an existing customer with an existing plan.
I'm not new I've been with them over a year and this plan since September 2024.
This is day 3 I can now make phone calls randomly not all the time. But no data and no messaging
funpig1
@Shane87
Are you an existing customer with an existing plan that is giving you trouble?
Are you a new activation customer having difficulty activating your plan?
Or are you trying to port in a number from another provider?
Meow
Contact agent using the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up by CSA). Click Chatbot - Ticket and type TICKET, then follow prompts. Link to create a ticket will be presented.
Sansan
There is no live telephone support.  All messages.  The chatbot is supposed to work. But if you say you cannot get around it, use the link.
They will respond via envelope.
hairbag1
@Shane87
if you dial 611, you should here current plan status.
