11-06-2023 03:18 PM
I’m currently not receiving texts from 2 numbers (both androids), and any time a code from my bank/security verification code is sent I have never received it. I have already tried: resetting my network services, turning on/off airplane mode, letting my phone stay dead for a few hours before recharging and taking my SIM card in and out. Anyone have any helpful tips on how I can receive texts?
11-08-2023 03:36 PM
Thank you for the detailed reply! No, my phone is a brand new iPhone (the 15) and doesn’t have my previous phone on the account. I tried your second suggestion and that did not work (I waited the last day to see if any change).
In your opinion, would a change in SIM card work at all?
11-06-2023 08:01 PM
@Ellbee - have you recently changed to a 'new to you phone'?
If you are iphone...Deregister the number on the iphone: https://selfsolve.apple.com/deregister-imessage/
Set up your phone number On your iPhone:
Or, try performing the following steps to try and fix the issue:
11-06-2023 03:42 PM - edited 11-06-2023 03:43 PM
@Ellbee So you are receiving iMessages from iPhones but not SMS text messages from Android? Perhaps your port was not completed. Is your account with your old provider still active? Are voice calls working both outgoing and incoming?
11-06-2023 03:30 PM
Hello! I ported my number just over a month ago already!
11-06-2023 03:19 PM
HI @Ellbee
did you just port in your phone number today or only for couple days? Usually it takes 24 or 48 hours for all calls to come to PM properly, for 2FA test, it can take even longer 3 to 7 business days. But this is normal
