04-18-2025 03:19 PM
It looks like PM has 2 lines? If gave me the option to label them & I had to pick what line I wanted for what, when signing up🤷♀️ I don’t know why there are 2 lines but I clearly did something wrong as I am having trouble sending texts, making & receiving calls, can someone break these down for me, I’m confused & at this point my phone is useless
thanks!!!
04-18-2025 03:54 PM
hi @mum1
look like the telus is a physical sim , remove it
then reboot phone, go back and you should see only PM sim there. Make sure it is set as Primary
04-18-2025 03:50 PM
Did your Telus account have a physical SIM card or eSIM? Did you port over your number from Telus?
Looks like that you have 2 eSIMs active. Try to turn off one of them and see what happens. If no different, turn off the other one instead.
04-18-2025 03:36 PM
both are the same phone #
04-18-2025 03:28 PM
hi @mum1
is Telus a physical sim? if telus is physical sim , remove it. But if Telus is an esim, disable it (do not delete it yet). Then reboot phoen and Reset Network Settings. Go back and check if Public Mobile esim is set as Primary, if not, change it
04-18-2025 03:25 PM
I was with Telus do have that dim in my phone (but I cancelled my service) and then I have PM eSIM.
04-18-2025 03:21 PM
hi @mum1
how many sim card or esim you have? they both Public Mobile? If you have only one Public mobile sim, the other non-PM should be removed or disabled. Public Mobile sim should be set as Primary
or can you show us what 2 lines you see? post us screenshot
