SMS notification @msg.telus.com
philip169382
SInce Monday, I no longer receive SMS to my #########@msg.telus.com
It was working at leat until last Tuesday
I've tried from 3 senders... No luck!
Anyone having the same issue this week
Nezgar
How many messages were you previously receivng via email-to-sms to your phone? It's possible your line somehow got blacklisted, or tripped some "overusage" status that is now preventing you from receiving any more via that service for now...
Also try the other SMS domain @msg.telusmobility.com
Also try the MMS domains:
@mms.mb.telus.com
@msg.koodomobile.com
@mms.telusmobility.com
@Meow- Most providers have an email method of emailing to a phone number which arrives as a text. In our case it arrives looking like it came from +19999999999.
Meow
SMS usually go to phone number (PM 647-580-xxxx). What this email has to do with SMS?
Hi @philip169382
Just tested myself and it works
are you receiving regular text ?  check that as well
Try reboot the phone first
Then try Reset all network if reboot does not help
hycm53
Turn off the phone, remove the sim card, wait a couple of minutes, inset sim card, then reboot the phone.
dust2dust
Worked for me. That doesn't help you 🙂
Your subject line says notification though. Is it notifications or the receiving of it?
Adding - curious why you're sending to you via email though. Is this some kind of automated system?
And maybe you blocked texts from +19999999999.
