SIM card not yet delivered
Balaji
Hi team,
I have ordered new SIM card online on April 26th still SIM card haven’t delivered. My order 290998. Can you kindly look into this issue.
thanks,
balaji m
JL9
Going forward you may want to look into alternatives to get the PM sim, both for price and receiving it In a timely fashion
HI @Balaji   Yes, it has been 10 days for your order.  But it could be another 10 days before you receive the Sim card.    The delivery time is just unreasonable.
Meow
Order from PM usually takes up to 3 weeks to arrive. Since SIM is sent by Canada Post. If you do not receive it until May 16th, you should inquire with the agent.
@Balaji   PM usually fulfill the order in 2 or 3 weeks.
You can open a ticket with PM Support for an update:
If you need the sim card urgently for activation, check with local mobile store.  Many of them will give it out for free if you activate with them
