My sim card
Shihab
Hi,
Where is my sim card?
2 REPLIES 2
HALIMACS
To confirm, @Shihab , you're not chatting with employees of Public Mobile on this forum.
We're just other customers like you.
After ordering SIM cards, they will leave Public Mobile's fulfillment centers within a couple of days, then they're completely in the hands of Canada Post.
If you need one quicker, try a corporate Telus or Koodo location.   If you go that route, you might be able to get Public Mobile to refund you the cost of the original one your ordered - but be sure they'll do this by asking them first.
Here's how:
  1. Use the ticketing system by clicking here , then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
hi @Shihab it is coming.. at the hand of Canada Post 🙂
how long you ordered?? it can be as many as 3 weeks but likely faster
if you already waited 10 days , ask support agent to check, message them here
