SIM card issue
Kam1818
Sometimes I lose connection when I'm talking to someone. All of the sudden my cell gets disconnected, and I see no service on my cell. I searched the issue and tried everything but didn’t fix my issue. I called Goggle and tried their solutions but didn’t work as well. They suggested to put my SIM card to another cell phone and if I have the same issue then it is the SIM card.
I tried it and I have kind of the same issue. In my Pixel 6a phone I lose connection and I see no service sign. But in my other cell (Pixel 2) the phone just gets disconnected. I check and I have connection but no idea why it gets disconnected.
Can the issue be SIM card?
@Kam1818
It sounds like the SIM contacts and not connecting. Try wiping the SIM contacts with rubbing alcohol and reset the Network setting.
HI @Kam1818
when you are making calls, check if it shows you are connecting to 3G or 4G (LTE). If it shows 4G while you are on a call, then there is a problem with VoLTE for you. If it is showing 3G, then you are not using VoLTe but 3G for voice.
you should also submit a ticket with CS agent first so they can refresh your account,  please submit a ticket with CS Agent here:
@Kam1818  Maybe try resetting network settings . See if that helps . Otherwise here’s direct link to support to investigate . Maybe they can reset your account on there end
send a  private message   To CS_Agents
