06-10-2023
02:32 PM
06-11-2023
11:07 AM
Dunkman
My Public Mobile SIM card won't send outgoing texts. It can receive texts, no problem, and send/receive calls. This problem persists no matter which phone the SIM in installed in.
I bought a new Public Mobile SIM card, and want to transfer my current Public Mobile number to the new SIM, but the ChatBot is sending me in circles.
1. Will changing SIM help?
2. How do I transfer my number from one PM SIM to another?
3. Any other advice?
Thank you!
06-10-2023 06:50 PM
Thanks, everybody! I will try having CS reset the account before I try swapping the SIM.
06-10-2023 05:15 PM
@xavierclaire41
It is very rare that it is your SIM. Always contact a CS_Agent to investigate the issue first unless the SIM is physical damaged.
Just have one question, did you just port your number over to PM?
If you did, did you reply to the text confirming you are porting over to PM with the old SIM in your phone?
The porting could be in limbo so you need to contact a CS_Agent to restart the porting process for you.
06-10-2023 03:45 PM
Several ideas, suggestions and questions for the op but no response since original post. Would be nice if op acknowledged everyone's input, at least.
06-10-2023 02:54 PM
@xavierclaire41 I think this is not a SIM card issue, but who knows..perhaps.
Before swapping any sim cards, I would always go to customer service first to reset your account. If same issues happen then, sure try the sim swap on your My Account.
See "How To Change Your SIM Card" in this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/change-sim-number
Other things to check or inquire about...
06-10-2023 02:51 PM - edited 06-10-2023 02:52 PM
@xavierclaire41 you can change sim by logging into My Account using only a computer, there are glitches if you submit the change sim request using mobile device. Just go to Profile page, click in the pencil icon besides the sim number
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
Likely it will resolve the problem with a new sim as sim will be reprovisioned.
But if you like, you can first ask PM support to re-provision your existing sim and could also resolve the problem without using a new sim card. You can message them at:
06-10-2023 02:46 PM
might be a bit premature to change sims yet. Maybe we can help diagnose the problem with your help.
What kinda phone you using ? Have you been able to send / rec texts in the past with this sim ?
06-10-2023 02:35 PM - edited 06-10-2023 02:38 PM
I don't think changing the sim will help this but you change it in the account. Log in to the site or app and use the change sim function.
What is the make and model of the phone? I would want to look at the SMSC number that is set on the phone.
Adding - but I see it's a problem in other phones.
