11-23-2023 06:59 PM
How do I get this fixed? I'm getting SOS on my phone. The number is ported but my SIM isn't activated. No service!
11-23-2023 07:22 PM
Thank you so much everyone! I opened a ticket and they ended up helping and now it works!!
11-23-2023 07:20 PM
@JChung0101. If physical SIM, remove the SIM card from the phone and gently reinsert.
Also, try restarting your phone or do a soft reset.
Definitely try another phone as @hTideGnow suggests first before submitting a ticket to public support agents, as this could just be a device issue.
11-23-2023 07:02 PM
@JChung0101 You need to submit ticket with support to re provision the sim for you
send a private message To CS_Agents click
VVVVV Link below VVVVV
11-23-2023 07:02 PM
HI @JChung0101
physical or esim?
if physical, did you try putting it on another phone?
if same, please submit ticket with cs agent here
