Roaming
05-31-2021 10:16 AM - edited 01-06-2022 02:48 AM
I live close to the USA border, and I often can't make a call or receive a call because I'm connecting to the USA tower. At these times, I also don't have internet.
Service
06-07-2021 05:21 PM
Samsung
06-07-2021 05:21 PM
@Lise3 : Is there an automatic switch? Turn it off and manual should happen.
06-07-2021 05:20 PM
@Lise3 What brand/model of phone is yours?
06-07-2021 05:20 PM
It is on automatic and doesn't give me the option to select manually. If I click on Network mode, it gives me 4 options. Two of which are...WCDMA ONLY and GSM only
06-07-2021 05:15 PM
When I click on Network Operators, it doesn't give me the option to select manually.
05-31-2021 03:54 PM
I dont have any problems in the Tsawwassen BC / Point Roberts WA area of BC. I do keep my phone locked onto Telus and Roaming blocked on my iPhone 6S. There is a relatively new AT&T tower in Point Roberts that certainly would be picking us up when we are (were!) there. Our service at Pt Roberts improved quite a bit when it went into service which tells me it is processing some of our calls at least.
Telus has agreements with US providers related to cell sites very close to the border. Not sure how it works but it allows “the other guy” to pick up calls and have it not become a roaming call as that would be a constant problem. Maybe blocking roaming will get it to work for you? Or maybe a cell site further across the border is getting you and it isn't part of “the Border Zone”.
AE_Collector
05-31-2021 11:31 AM
Didn't you say there was some kind of agreement with telus about this type of thing happening?
05-31-2021 10:36 AM
Change your mobile network settings from automatic to manual and simply connect to the PM network.
05-31-2021 10:22 AM - edited 05-31-2021 10:23 AM
@Lise3 , Yes, your phone might have picked up the wrong carrier because of a stronger signal
What kind of phone do you have ? iOS? Android?
you will need to manually select PM
On some Android, here is how to
If you check Connection->Mobile Networks->Network operator , select the option "Select Manually", wait a bit and you should see a list of available carrier, choose Public Mobile.
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- 1
- 2
- Next »
