07-13-2021 09:43 PM - edited 01-06-2022 02:48 AM
In coming calls are going to voice mail.. some times there is no record of the incomming call
07-13-2021 10:58 PM
@gehman5 wrote:we were getting calls but all of a sudden its going to voice mail
Hello @gehman5 ,
The phrase 'all of a sudden' is sometimes unnerving.
If your other texting and data services are also not working (as @Anonymous posted already) check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
How long has this been happening? And was everything working before this started?
Some trouble shooting - try one or more of the below:
*ensure "Do Not Disturb" was enabled by mistake
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
07-13-2021 10:18 PM - edited 07-13-2021 10:20 PM
@gehman5 : Maybe have a look at devicecheck.ca
Edit: although that wouldn't be relevant if outgoing and text and data works.
07-13-2021 10:13 PM
What kind of phones do you have?
you might try want to change your network to "3G Only" for couple days and see if that helps.
07-13-2021 09:55 PM
07-13-2021 09:48 PM - edited 07-13-2021 11:40 PM
@gehman5 wrote:In coming calls are going to voice mail.. some times there is no record of the incomming call
Are you a new customer?
If you asked for a number to be ported in, re-insert your old carrier's SIM card as porting isn't compete. The voicemail that callers are hearing could be of your old carrier.
If you haven't asked for a number to be ported in, try setting your network type to 3g-only/WCDMA-only/HSPA-only.
