Roaming
05-31-2021 10:16 AM - edited 01-06-2022 02:48 AM
I live close to the USA border, and I often can't make a call or receive a call because I'm connecting to the USA tower. At these times, I also don't have internet.
Service
06-07-2021 07:47 PM
After selecting search for networks it took awhile but eventually the available networks comes up that you can then manually select and you should only connect to that network and your phone will not automatically scan to connect to the closest available network available to you. (In the US this would be T-mobile or at&t who pm has roaming agrerments with for their add ons.)
06-07-2021 07:30 PM
Ok, thanks...I'll do that. You've been very helpful (and patient).
06-07-2021 07:25 PM
@Lise3 : I may be wrong but I think the act of manually scanning for and selecting a provider bypasses the automatic. If you were to now touch Select automatically that then you would be going automatic. But I could be wrong. So don't anyway. Give it the next while to see if your phone wants to connect to a US tower.
06-07-2021 07:25 PM
My Summer home is right on the border of New Brunswick and Maine. This is where I'm having a problem making and receiving calls
06-07-2021 07:14 PM
You can ignore the “Welcome to the USA” text that tells you what calls, texts and data will cost you. You aren’t going to be charged, there isn’t a mechanism to charge you. It will either work or it wont work as part of your plan. If very close to the border I think it will work but maybe not. Roughly where is this happening?
AE_Collector
06-07-2021 07:14 PM
I think you are perfect in terms of selecting the network manually
this is a demonstration: (haha.. don't choose Vodafone)
06-07-2021 07:11 PM
Yes, that is where I am
06-07-2021 07:09 PM
06-07-2021 07:08 PM
But it isn't on Manual...it's still on automatic. Fortunately it is on PM. I guess I'll have to wait and see what happens next.
06-07-2021 07:04 PM
@Lise3 : We're asking about now. We understand the past experience. If it's on manual and set to here then it _shouldn't_ (famous last words) try to connect to anything else and therefor _shouldn't_ send those texts.
06-07-2021 07:01 PM
Yes, it says Public Mobile
06-07-2021 06:57 PM
@Lise3 wrote:Unfortunately, it still connects to US towers. What Network Mode should I be in?
After you select Public Mobile from the list, what do you see on the very top of of your phone screen? it will show you the name of the operator your phone is connecting.
(ideally, you should be seeing Public Mobile)
06-07-2021 06:55 PM
Yes, I get those texts, but it would cost me 10.00 for 10 days. I'm not even in the US.
06-07-2021 06:53 PM
06-07-2021 06:49 PM
@Lise3 wrote:When I press OK, it says Registered on Network
that is good.. you should see Public Mobile on top of the phone... you phone is now just talking to PM and not the US
06-07-2021 06:49 PM
@Lise3 : If you're not in automatic mode then it should stay connected to Public Mobile. When in automatic mode, it sees the US towers as stronger signals and they take over. But you should get texts welcoming you to the US when it does that.
06-07-2021 06:49 PM
@Lise3 after you Search Network, the page because Select Manually I think. When you click PM, it should hold on to the Public network.
At least right after you clicked PM as your network, it should stop connecting to the US carrier....
06-07-2021 06:48 PM
06-07-2021 06:46 PM
Yes, Public Mobile is there...when I click on it, it becomes my Network Operator. But that's what it was before, and I was getting on US towers
06-07-2021 06:43 PM
@Lise3 : Mobile hotspot is an extra on top of mobile data. Don't worry about it for this purpose. Is there not anything to touch when it asks about disconnecting? Like an OK or Proceed or whatever. Might you need to scroll up or something? Because you're in the right place. You just need to let it proceed. Thus my while-on-mobile quick answer of let 'er rip.
06-07-2021 06:29 PM
@Lise3 wrote:It's a Samsung Galaxy A5
I have the the first two on your list
What happen if you click Search Network, do you see Public Mobile?
It might take long for it to return the list. You might see other US operators, too
06-07-2021 06:08 PM
Should mobile hotspot be on or off?
06-07-2021 06:05 PM
06-07-2021 06:03 PM
Stop using current data service and search for other available networks
06-07-2021 05:48 PM
What model of Samsung is yours?
in the Network operators, you don't have something similar to this? (make sure you are no in Airplane mode)
06-07-2021 05:45 PM
@Lise3 : What options do you have when it asks to stop using the connection?
06-07-2021 05:39 PM
I'm still not able to switch from automatic to manual...can someone help me please?
06-07-2021 05:35 PM
Let er RIP?
06-07-2021 05:28 PM
Let 'er rip.
06-07-2021 05:26 PM
When I click on automatic, it says Disconnect network. Unable to search for networks while data service in use. Stop using current data service and search for other available networks?
