03-14-2024 05:11 PM
I got a message that I received 240 GB of data from Public mobile but it won’t work
03-14-2024 06:08 PM
@Austinnnnnn Might you have changed to a lower priced plan? The bonus data will be removed if you do that.
03-14-2024 05:58 PM
@Austinnnnnn wrote:I got a message that I received 240 GB of data from Public mobile but it won’t work
By any chance, are you on a plan that includes unlimtied data at reduced speeds? Up until now, Canada-wide data add-ons have never worked with such plans. I'm curious to know how Public Mobile handled this.
03-14-2024 05:33 PM
hi @Austinnnnnn you sure they added you the data already?? some got it already but not everyone
check your My Account using incognito/private/secret mode on the browser and check again, see if the bonus data arrived
and make sure your phone does not have any data limiter enabled
if you need , ask support agent to help,please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-14-2024 05:15 PM
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
03-14-2024 05:14 PM
I have tried restarting my phone and have used all my subscription data
03-14-2024 05:13 PM
@Austinnnnnn Try rebooting the phone first . Also note it won’t start to be used until you use up your plans data bucket first . Only then it will automatically kick in for use
