US add on data
RazRee
Hello! I tried searching for this in the forum and couldn’t find anything. I used rewards for data roaming in the US recently for 15 days. If I don’t use the US roaming data, for the time it’s valid does that mean I can’t use the rest as local? (Ie Canada plan 6 gb, US 3 gb for 15 days).
@RazRee
if you want to get data on the cruise, it is actually much cheaper to buy the onboard Wifi instead of any mobile networks that work on the cruise.  Buy before the start of the cruise, they usually have 20% off.  Yes, it is not cheap, but it is the only way to keep connected
RazRee
I’ll try this. I used my rewards for use in the states and I didn’t even use 1gb out of the 3gb I was given. No harm in trying. I just wanted to see if it could roll over. Thanks for the response.
RazRee
PM doesn’t work on cruise ships and more specifically Celebrity. Recently came from Alaska where I got great reception with AT&T, spotty in the smaller ports but the roaming data worked well and no charges. Im too cheap to purchase wifi on a cruise and they used Starlink. has anyone recently used any cruise afflliated cards or providers?
@RazRee
US roaming data is only for used in US.  If you didn't use up the data while you are in US, you cannot use it in Canada
but if you didn't use it at all, like you cancelled the trip or so, you can ask PM CS agent and they might be able to reverse the transaction for you.
To contact PM CS agent
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
