Incoming call does not working
Mzhang100
Outgoing call is OK and all Text Message is working as well. when someone dialing my phone number, there is no dialing sound, just a silence. Thanks
self solution removed
Mzhang100
Thanks and it is now working.
Mzhang100
Thank you for Quick answer.
yes, I got a physical SIM. Reset my phone seems not helping. I will try another phone when I back home. By the way, how to reset network? You mean the Wi-Fi ? My phone dateline is fine. Cheers
TheSterlinger
@Mzhang100  reset networks and see if that will help.
You got physical SIM card? Test it in another phone to determine if sim issue or phone issue.
