09-18-2024 05:07 PM
09-18-2024 06:04 PM
self solution removed
09-18-2024 05:58 PM
Found it!!! Thanks for the help.
09-18-2024 05:47 PM
@Mo88 Is this from the app or website? If app you can try to close app, reopen and see if it will load. If it's website you can try to load browser in incognito or in private browsing and see if that will work for you.
09-18-2024 05:14 PM - edited 09-18-2024 05:20 PM
hi @Mo88you were using the Rewards link from the pop up when you login? don't use that. Close the popup and use the Rewards link on top right of the page after you are in My Account
or you can simply use this link
