Rewards I ordered didn't work
Freedom551
Visiting USA from Canada. Purchased the US talk & text package using my rewards the morning I left. Points were deducted from my account so I assumed all was well. I received the Welcome to the USA message but after reading it I see it doesn't say anything about being covered by the US Roaming talk, Text & Data package I redeemed.
Any ideas on how to get the package I ordered?
Thanks! Kat
12 REPLIES 12
Freedom551
Thanks to everyone for their help! I re-sent manually to T-Mobile (not AT&T) and my phone now works. Much appreciation! Kat
Freedom551
Sorry, change that. I didn't do a reset. Can you tell me how to do that please?
HI @Freedom551
try a Reset All network and try both T-Mobile and AT&T agian
if same,  please submit a ticket with CS Agent here and they can confirm if the add-on was purchased and added correctly:
Freedom551
Thanks for the info - I've done all that 🙂
Freedom551
Roaming on, connected to AT&T. Still can't call out or get incoming.
Thanks for the info!
HI @Freedom551
try manually connect to T-Mobile instead
Freedom551
Thanks for the reply. Bought the US data,  talk & text.  Data roaming on. Phone says the network is AT&T.
Freedom551
Thank you for the info.
Phone is connected to AT&T but when I try to make a call, it doesn't even ring and says 'call ended'.
Data roaming on.
Haven't tried to see is I can use my data yet.
Have been here many times and it always worked before.
@Freedom551
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
If your issue is with data, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter.  Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
If your issue is with voice, make sure VoLTE is enabled on the device setting.  And if it does not work, try to change the Network to T-Mobile ONLY, and change  Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data  is working
@Freedom551  Did you get the correct US roaming add on and not just US long distance mins ? Also make sure your data roaming is turned on in phone settings and your connected to T mobile or AT&T and rebbot the phone . If wrong add on purchased please submit ticket with support to try and reverse it for you
send a  private message   To CS_Agents
Sansan
Just enure that you have roaming on. Connect to At&T or T-Mobile.
Should work.
Ignore the welcome message.
HI @Freedom551
no worries about that text, that is a default sms everyone gets with or without US addon
if you got the US roaming addon, try to connect to T-Mobile or AT&T first, and make sure Roaming Data is enabled on your device
