06-15-2024
03:30 PM
06-16-2024
12:58 AM
computergeek541
Mising 300 gb data giveto me when they changed me from old rewards progrom to not a better rewards program by no mines. An now i dont see the 300gb. An yes i didn't use them up since i didnt use up my month amt. Maybe some customer service agent could back to me.
06-15-2024 03:38 PM - edited 06-15-2024 03:39 PM
Hello @Bwesties2
There are three reasons why they may be gone.
1. You used them up. But that's out.
2. You changed accounts to a lower monetary amount. This will trigger loss of data bucket according to PM.
3. The 5 months is up. It's only been maybe a month so.. nope.
If you haven't changed plans and are currently on the same plan that the data was given to you on, please contact a CS Agent to investigate.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
06-15-2024 03:32 PM - edited 06-15-2024 03:33 PM
You will lose the bonus 300gb data if you downgrade to a lower plan but it will remain if you upgrade your plan. It is noted in the fine print.
Did you downgrade your plan?
If you didn’t downgrade them submit a ticket to an agent to investigate on the Chat bubble.
