3 weeks ago
Hi Everyone,
I am currently on $34 50 GB Can-US plan and I would like to downgrade it to $29 20GB 5G Can-US-Mex Plan. How can I do it ? Just want to be sure before I try any change of plan. The downgrade option doesn't show up when I go to Change Subscription. However this new plan is available to new customers only. On searching the forum, I found some pointers where some of the members mentioned that we have to switch to another plan and change it.
Can I achieve by following this ?
1) Change subscription $30 20GB Data at 4G Speed and then do another change to $29/20GB 5G Can-US-Mex ? Is this switching option available when I change subscription to $30 20GB Data at 4G Speed ?
Regards,
VH
3 weeks ago
Before the change I was able to see the $35 plan as I was on the $34 plan. I never go over 5gb per month. So this 20gb 4g plan will work fine as well. Too bad I cannot go with the other 20gb plan.
3 weeks ago
@Anotherpaul778 So you just did immediate plan change to the $30 plan ? You should at least see the $35 75GB MEX roaming plan . And that's awesome deal too just make plan change to it using change on renewal option . If you want that plan would be nice if it would work for the $29 plan but no one has confirmed that works it’s just to get the $35 plan
3 weeks ago
Does not work. Just tried now.
3 weeks ago
Thanks @Phil_Adelphus . Yeah it looks like I wont be able to switch it to $29 plan from the comments from @Handy1 . Thank you so much for the response.
3 weeks ago
Thank you so much @Handy1 for the information.
3 weeks ago
@hegdvin Because it’s harder to downgrade plan price these days just upgrade plan price . pM outs targeted offers to existing customers despite what we see on the website . So you can only have to what you see available to you in your account . If you do immediate plan change to the $30 plan , you won’t see the $29 MEX plan but you should see the $35 75GB MEX plan cable to make change to fit next renewal be the best deal you can get as existing customer . And that would be cheaper work around for one of the spatial boxing week plans then porting number out and back in on desired plan
3 weeks ago
@hegdvin I haven't see anyone say that they downgraded to the $30 plan and then saw the $29 plan. Where people have been doing this is to reveal the $35 plans. Since Public Mobile has started limiting what plans we each see and it's not always the same, it's harder to go down a level in cost so unless someone has tried what you are suggesting and can comment there's no way to know if it would work.
