Reward minutes
Carole8
Can I use reward minutes to use Public Mobile while Spain on holiday ?
7 REPLIES 7
Carole8
Thanks!
Carole8
Thanks for clarification!
hairbag1
@Carole8....
have you considered using a free voip app like TextNow. It uses your wifi or data and you can send / receive free calls / texts while abroad using wifi. Most resorts, cafes, public areas have free wifi ...you might just have to ask for their password. I've used it and seems to work good. If you buy a local sim and a cheap data plan, that works with voip apps as well as wifi. There's other free voip apps to use... but I'm happy with the TextNow app.
HI @Carole8
no , the reward minutes is to call from Canada only.  They are not roaming minutes
There is no roaming service in Spain for PM
Please use local data prepaid.  You can also use VoIP app Textnow to call back Canada or give that phone number to your friend to call and text you
Yummy
No. PM provides service in Canada and US with US add-on only.
Reward minutes are for calling FROM Canada to selected number of countries.
hycm53
No. PM service is only in Canada, or add-ons in USA.
Outdoorsman
@Carole8 hi public does not work outside Canada except US with an add on sorry
