Website issue
Grahamn
My personal phone number has been listed as the contact number for Kamloops BC Aberdeen mall on the Public mobile website and I am constantly receiving unwanted calls. I am not a customer and have tried SIMon and phoning and emailing but all to no avail! Can someone fix this!!!!
Meow
Where do you see that number on PM web site?
I cannot find ANY number on PM site??????
Hi @Grahamn look like something you need to open ticket with PM CS agent
at : https://publicmobile.ca/chatbot
First type Contact CS Agent,
then select the only choice there:  "Contact..",
from the list of ,  choose "Other"
finally click the the blue link about submit a ticket
walker1
@Grahamn   You might want to consider joining Public Mobile and then you can change your phone number up to 4 times a month for free.    But seriously, that's got to be really annoying and make you want to pull your hair out 🙂
dabr
@Grahamn   Depending on how important your number is to you, you could opt to login to self serve and change your number as PM permits 4 number changes per 30 days for free.  Select Change Number from the Quick Links or Profile page, although there's no guarantees that spam calling would stop as we all receive them from time to time.
edit:  oops, nvd just re-read that you're not a customer. Sorry.
edit 2: @Grahamn   You can send a private message instead to CS_Agent if having problems with the chatbot ticket.  Here's a link:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
buildingbid
They might fix it but it will probably take a long time so just be patient 😃
